CCB021M12FM3 installation
                    David_William
                    Contributor Level 1
            - Could I apply for the footprint file of CCB021M12FM3?
- When I use CCB021M12FM3, could I solder this module to the PCB instead of using the press-fit contact method?
Thank you!
            Hi David, - Yes, we can supply the footprint file for the 21 mΩ six-pack FM3. Which PCB layout software are you using?
- Yes, you can solder the module into a PCB instead of performing the press-in procedure.
 Best Regards, Austin C. 0
            Layout software: Altium Designer (21.0.8). Many thanks for your response! David 0
            Hi David, We have send the footprint files to you via email. Regards, ArunA 0
            Thanks so much for your kind response, I will have a test of this module based on your footprint! 0
