Eoss loss consideration in hard switching
            Hai,
I have a query on Eoss consideration for switching loss. My application is on basic 2-level SPWM inverter design. I want to calculate the switching loss during hard switching. For that, is adding Eon, Eoff from the datasheet sufficient? Otherwise, it is adding Eon, Eoff, and Eoss from the datasheet. I was told that Eon and Eoff will have the Eoss inclusive, and just adding Eon and Eoff is sufficient. Is this true for hard switching? for soft ZVS Eoss won't be there so no need for Eoss addition. What is the case in Hard switching. Thank you.
            Thanks for the questions. Yes, you may be right - Eon and Eoff will have the Eoss inclusive, and just adding Eon and Eoff is sufficient. We'll do further study and validate this. For soft ZVS, Eoss won't be there so no need for Eoss addition. 0
            Hello, We're still working on validating the answer. We will reach out to you as soon as we have something. Thank you! 0
