Output of the Auxiliary power board
When I test the output voltage P_15V and D_6.5V of the auxiliary power board for CRD-22AD12N (just give the power to auxiliary power board, not connected to the main power board), I got 18.6V and 9.8V respectively, why this happens?
Thanks~
Hi Jimmy
You are correct. When you will test auxiliary power board without connecting to main board, you will get 18.6V and 9.8V as you mentioned. But, when the auxliary board is loaded and connected to the main board, you will get 15V and 6.5V respectively.
Hi, I hope that this answered your question. I will close this discussion for now but if you have a follow up question, please "Start a New Discussion" and we would be glad to support you further
