the output voltage of the CRD25DA12N-FMC 25 kW Three Phase Inverter?
                    Sema_Akyuz
                    Contributor Level 1
            What is the output voltage of the CRD25DA12N-FMC 25 kW Three Phase Inverter?
data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAAngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2dwmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAnwbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFYl8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6dyISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC
            Hello Sema_Akyuz, Thank you for your question. The output voltage for the CRD25DA12N-FM3 three-phase inverter is dependent on the operating conditions selected by the user including the control scheme, input voltage, and modulation factor. A common operating configuration for the circuit is to use space-vector pulse width modulation with VIN = 800 VDC and VOUT = 480 VAC. Thanks, Chris N. 0
            Thanks for your attention, have a nice day 0
