CPM3-0650-0015A : Switching Energies and LTSpice model
BPasquet
BPasquet Contributor Level 1
edited November 17 in Bare Die Products
I am looking for a graph of CPM3-0650-0015A bare die SiC MOSFET's switching energies depending on drain current, drain-source voltage and Grid Resistance. Do you have this information available ?
I am also interested in an LTSpice model of the component, if you happen to have one.
Thank you,
B. Pasquet
  • AustinC
    Hi B. Pasquet,
    I recommend utilizing the C3M0015065K device's datasheet to determine the switching energy vs. current and gate resistance for this die. There is also a LTspice model available for the C3M0015065K available here.
