Need confirmation on the required software to run CRD-06600FF065N-K kit and design calculations
Hi Team
I am currently working on CRD-06600FF065N-K eval kit can you pls confirm from your side weather below are the required software to run the kit pls confirm through the email provided and can you also pls share the detailed design calculations.
1.Cree GUI from wolfSpeed (we need access to run ECANTest.exe file which we got from vendor to access the GUI).
2.ECANTools software developed by vendor for WolfSpeed Eval Kit (CRD-06600FF065N).
3.Need to install the below provided Drivers by Vendor.
If possible, can you arrange a demo for the Kit to show how to power up and get the readings and collect the graphs. currently the kit is available with us
With regards,
Chakradhar
cb.en.p2ael24009@cb.students.amrita.edu
Greetings:
All the available design files, documentation, and firmware is posted on our website for download. Please see the user guide for instructions on using the firmware and GUI.
Julius R
Hi julius,
I have gone through the documents in website there is no design calculation xlsx files if possible can you pls send .and also can you pls confirm the required software through the email so i will be helpfull to install in my system.
ThanksG chakri
Greetings:
There are no additional design calculations. All available software is in the firmware zip file that you downloaded.
Julius R
