CRD-30DD12N-K reference design : use of the EEPROM IC of AT24C16D
With respect to the reference design of CRD-30DD12N-K, I have a question on the control board.
It seems that the EEPROM IC of AT24C16D is employed on the control board.
I wonder what its purpose is.
With regards,
GKIM
            Hi GKIM, EEPROM is a read only memory, which is used to save data by CAN communication. The main purpose is to get the current/voltage sampling data and curve. Thanks! 0
            Hi Iris, Thank you for your review. Do you mean that the EEPROM saves the data such as the voltage reference and current reference which the DSP receives from the Windows C# GUI by CAN communication? Thank you for your consideration. With regards, GKIM 0
            Hi GKIM, Correct, or you need to get the curves by CCS graph online. 0
            Hi Iris, Thank you for your review. How can I get the Windows C# GUI? Would you please share the GUI program? Thank you for your consideration. With regards, GKIM 0
            Hi GKIM, If needed, please contact the local sales team to support you. Thanks! 0
