XM3 Inverter CAN Interface
            I would like to connect the CRD300DA12E-XM3 inverter with a Can adapter from isCAN of the company Thosis. In the XM3 inverter application I can select the isCAN adapter. But there is no information how to configure the adapter.
How can I use an isCAN adapter? The connection between adapter and inverter works (tested with standalone application by Thorsis).
            Hello, The isCAN interface is compatible with the python-can library that our GUI is based on, but we have not internally verified this hardware interface to date. Can you verify that the Channel and Bit Rate inputs for the inverter GUI match the port configuration for the isCAN adapter? Thanks, Jonathan 0
