10-15kw 60hz Single Phase Inverter Subsystem Need:
As a systems integration engineer, I need a SiC inverter subsystem with a minimum of 10kw/60Hz/Single Phase output in the North American Service Voltage range for 240/120 split phase operation from a ESS source with an output working range of 370-400vdc. ESS charging/BMS will come into the picture, but we need to get a better handle on that when speaking to the designer/supplier.
Being early in this project, we can be quite flexible on form factor, temp control, etc. This will be for a stationary application so space is not a premium, but comfortably derated, unattended reliability is a very strong need.
I would be interested to hear suggestions , comments or PMs about paths that I might pursue to get there in a reasonably sensible period of time.
All inputs are appreciated!
Bruce
            Hello Bcavendar, I think the sales team might be able to best assist you for this. You can fill out the form at https://www.wolfspeed.com/contact/ for Power and our sales team will contact you soon. Thank you so much! 0
