Transformer "ATWPPQ656264A200P" used in CRD-22DD12N
            Hi Every one,
I have a query regarding the transformer (ATWPPQ656264A200P) winding that is used in the reference design of the 22kW Bi-directional High-Efficiency DC/DC Converter "https://www.wolfspeed.com/crd-22dd12n/.
What should be a way of winding placement on the bobbin,
- Option:
Half of the high-voltage winding
Full low-voltage winding
or
2. Option:
Full high-voltage winding
With proper Isolation between windings and core as per standards (in both cases)
Please suggested which option must be preferable and why?
Pemendra Kumar Pardhi
            Hi Pemendra, We have the independent resonant choke there. To minimize the leakage inductance, the first one is better. Half of primary winding//secondary winding// Half of the primary Regards, Frank 0
            Hi Frank Thank you for your kind suggestion. Thanks & Regard Pemendra Kumar Pardhi Sr. Power Electronics Design Engineer CastNX Pvt. Ltd. Dewas, India 0
