Physical Properties of 4H-SiC
I have received a request from a customer to provide data on the physical properties of your 4H-SiC.
Can you provide data on the following three properties?
1) Thermal conductivity [W/(m x K)]:
2) Density [kg/m^3]
3) Specific heat [J/(kg x K)]
The customer's objective is to simulate thermal and stresses.
Thanks for your support in advance.
Alen
            Hello Alen, Thanks for your inquiry. Below is the information on the thermal properties that you requested. 1) Thermal conductivity [W/(m x K)] = 342 2) Density [kg/m^3] = 3.21 3) Specific heat [J/(kg x K)] = 552.42 Thank you! 0
