Reverse recovery losses not calculated in PLECS using Wolfspeed's XML
Prathik
Contributor Level 1
A couple of weeks back, I received an under-development XML file for the Wolfspeed CAB5R0A23GM4 from Blake. I created 1500V a boost converter model using the Wolfspeed custom MOSFET component and the XML file to get the junction temperature and losses.
I noticed that the model doesn't seem to calculate the diode reverse recovery losses, even though it is modelled in the XML.
Am I using the model incorrectly in any way? I have attached the model and XML to this post. It would be good it somebody could take a look at it.
