Do you provide complete FOC firmware (with speed and current control loop) for CRD600DA12E-XM3?
wuwei
Contributor Level 1
I'm thinking of using CRD600DA12E-XM3 600kW inverter to drive my PMSM motor, User Guide (https://assets.wolfspeed.com/uploads/2021/05/CPWR-AN47.pdf) shows that Wolfspeed provides example firmware but it seems only can do open loop control. Can you provide me complete FOC firmware that can run motor in current and speed closed loop?
Wei
Hi Wuwei, Thank you for your post. Currently, we do not have FOC firmware to run the motor in current and speed closed loop.
Our partners, Texas Instruments might be able to help. You may post your request at the link below and reference the Wolfspeed CRD600DA12E-XM3 inverter in your post.
