SpeedVal Kit™ Control Card
Dear Wolfspeed. I recently bought the complete SpeedVal Kit excluding the control cards because they were not in stock from the suppliers. Please I want confirm if the microcontroller TMS320C2000™ TI can work with the SpeedVal Kit motherboard because it is available in my location.
Hello Fredy,
The SpeedVal Kit was designed to work with the TI TMDSCNCD280039C control card (https://www.ti.com/tool/TMDSCNCD280039C), or any other TI control cards with the same 120 pin interface, as well as the NXP HVP-56F83783 (https://www.nxp.com/part/HVP-56F83783#/). Both of these boards are in stock in distribution (Arrow & Mouser currently) or through TI.com for the TI board.
If you choose to use a different control card that has the same interface, you may do so, but you would need to modify the firmware or create your own to be compatible with the DSP you select.
Please let me know if you have any additional questions.
-Adam
Hi Adam, noted.
Thank You
