PSPICE model for part Number EPM3-1200-0017D
Hi, I am kaviarasu and performing EMI simulation using ANSYS tool. I am using the Mosfet with Part Number EPM3-1200-0017D for automotive applications. In website only LTspice model is available, where ANSYS won't support for analysis and need only PSPICE model. Kindly I request you to share the PSPICE Model for part number EPM3-1200-0017D.
This model is listed under LTspice as this is our primary SPICE tool; however, you should be able to import this model as PSpice model as its syntactically compatible with the two tools. Please let me know if you have any trouble.
Zack
Whatever the LT spice model available in website is Encrypted model. ANSYS Designer will accept only the unencrypted PSPICE model not the encrypted model. Please do the needful.
Kaviarasu
That's interesting - we don't encrypt any of the models that we make available on the webpage. I went and downloaded the models from our webpage to verify and attached the requested die model here. Please let me know if works!
Zack
I have attached a document for your reference. Please help me to resolve the issue.
Kaviarasu
Hi Kaviarasu,
The error that you are receiving is a result of Twin Builder not processing the ddt() function that calculates the time-varying voltage in the non-linear capacitors for the device. There are a few ways to handle this but I recommend replacing the current sources (G11/G12) with the linearized capacitance that represents Cgd and Cds, respectively. For this device, you can use 204pF for Cds and 14pF for Cgd.
I hope this helps.
Zack
