the output voltage of the CRD25DA12N-FMC 25 kW Three Phase Inverter?
Sema_Akyuz
Contributor Level 1
What is the output voltage of the CRD25DA12N-FMC 25 kW Three Phase Inverter?
Hello Sema_Akyuz,
Thank you for your question. The output voltage for the CRD25DA12N-FM3 three-phase inverter is dependent on the operating conditions selected by the user including the control scheme, input voltage, and modulation factor. A common operating configuration for the circuit is to use space-vector pulse width modulation with VIN = 800 VDC and VOUT = 480 VAC.
Thanks for your attention, have a nice day
