Speedval Evaluation Kit Current Sensing
Good Day,
We are troubleshooting the current sensors on the Speedval Evaluation Kit and we would like to understand why the when we probe the current sensor outputs and output from the op amp circuit it does not follow the current waveform. The output from the op amp was smoother but we removed the 2.2uF and 100nF to try and get the signal to follow the current waveform. Any assistance or explanation you can give for this would be greatly appreciated. Thank you.
Can you please identify where you are measuring the 3 waveforms shown in the scope plot?
Adam
Good Day,
We were probing the wrong current for the yellow waveform. We probed the correct one and found that it was what we expected. Thank you for your help.
Surendra Naidoo
Glad you found a resolution!
I'll close this post. Please start a new discussion if anything else comes up.
