Is C6D10065G recommended using wave soldering?
WEN
Contributor Level 2
Dear WSer,
Is C6D10065G recommended using wave soldeing? because I just seem the wave soldering of through hole by PRD-05653.
Hey Wen,
C6D10065G is a standard SMD part and it is recommended to attach it to your PCB using a standard SMT reflow process but can also be attached using wave soldering if the assembly requires this type of attach method. When performing wave soldering, SMT adhesive should be used to attach the parts to the PCB before wave soldering.
