Press-In Fixturing for CCB021M12FM3
Where can i get the Press-In fixturing for the SiC Module ""
I do not get an answer via mail when requesting this nor is somebody picking up the phone German Office.
I would like to have the CAD file for it asap, to proceed with testing my design.
Kind regards
Hi Sleitenmaier - thanks for posting. We have assigned an engineer to work with you on this.
Hello sleitenmaier,
Please find press-in fixturing for the FM3 attached to this post.
This fixturing was designed specifically for our testing equipment. We used counterbored holes for socket head cap screws. You will likely need to adjust how the base and fixture mount to equipment available to you.
We also utilized guiding dowel rods from McMaster-Carr, part numbers shown in the assembly. These may not be necessary, depending on your setup and design. Tolerancing on these holes may be important.
Brett
Thanks a lot!
