Why do your two data sheets have the same ton and toff for different drive resistors?
mika_233
Contributor Level 1
Why do your two data sheets have the same ton and toff for different drive resistors? The device we purchased in 2023 measured ton and toff much more than you gave us. Please give a reasonable explanation!
In the last branding update the test conditions were not updated correctly. Please consider the conditions from the original document. The next revision of the datasheet will correct the mistake.
-Paul
