25kW Three phase inverter - CRD25DA12N-FMC
Ujala_MG
Ujala_MG Contributor Level 2
edited January 6 in Module Products
Please let me know, what are the DAC output pins of the F280039C control card which is used in CRD25DA12N-FMC or the inverter board.
Otherwise, is there a way to do debugging while using this product?
Thank You!
    Hello Ujala_MG,
    Thank you for your interest in this product. The CRD25DA12N-FMC does not use any DAC pins. You can debug the board using the controllable LEDs, the general-purpose IO pins routed to the spare connector, and through the CAN interface.
    Ujala_MG
