Material for PCB Carrier in CRD600DA12E-XM3
Duclair
Duclair Contributor Level 2
edited March 2025 in Module Products
I would like to know what material was used to print/build the Gate drive PCB Carrier in CRD600DA12E-XM3. this is because there are different high voltage levels on the gate drivers and the carrier is in close proximity to each of them, is the carrier in plastic or is it painted metal of some sort?
Thanks.
    Hello Duclair,
    The gate driver carrier is made from powder-coated aluminum. It has been extensively tested to ensure no voltage proximity issues.
