Which control card is correct for evaluation with CRD-25BDA6512N-K
ayazserhat13
ayazserhat13 Contributor Level 1
edited April 2025 in General
Hi Wolfspeed Team,
i want to be sure, if CRD-25BDA6512N-K is compatible with TI controller TMDSCNCD28379D (TMDSCNCD28379D Daughter card | TI.com) ?
    edited April 2025
    hello ayazserhat13,
    Thank you for pointing this out. There seems to be an error on the user-guide for CRD-25BDA6512N-K. The design is compatible with TMDSCNCD280039C- https://www.ti.com/tool/TMDSCNCD280039C.
    Initially, TMDSCNCD28379D was considered that is why you'll see a footprint compatibility with that control card as well but the final firmware, layout optimizations and testing has only been done with TMDSCNCD280039C. Thank you!
  • ayazserhat13
    Hello TBhatia,
    wenn i compare pinout for each boards, i see that TMDSCNCD28379D can be used with some sw modification. Am i right? Can you share with me firmware for TMDSCNCD280039C or is it available with C2000 from TI?
    Thank you in advance.
    You can request the firmware from CRD-25BDA6512N-K's product page. If the request is approved, the firmware based on TMDSCNCD280039C will be sent to you on the email id you provide.
    https://www.wolfspeed.com/products/power/reference-designs/crd-25bda6512n-k/
    Yes TMDSCNCD28379D may be used with some modifications that the user will have to make. However, we don't support the firmware with TMDSCNCD28379D.
