Thermal Cycle Resources XM3
Egor
Egor Contributor Level 1
edited August 20 in Module Products
Hello! The reliability of the inverter depends on the impact of thermal cycles on the power module. Is there a thermal cycle amplitude/quantity curve for XM3 power modules? Thank you!
  • AustinC
    Hi Egor,
    The images below illustrate the thermal cycling (thermal shock test) applied to the EAB450M12XM3 module during product qualification.
    Thermal Shock Test from AQG-324
