Parasitic capacitance of CAB450M12XM3
TKishi
TKishi Contributor Level 2
edited October 2025 in Module Products
Have the min/max values ​​for Ciss, Coss, and Crss for the CAB450M12XM3 available?
The test conditions are as described in the datasheet and there are no problems.
Best Regard
T Kishi
  • sjjimenezc
    sjjimenezc Wolfspeed Employee - Contributor Level 1
    Thank you for your inquiry regarding the capacitance characteristics of the CAB450M12XM3.
    Please note that while the minimum and maximum values for Ciss, Coss, and Crss are not specified in our datasheet, we do provide typical capacitance values at 800 VDS, 100 kHz. For a more comprehensive understanding, I encourage you to review Figures 8 and 9 in the datasheet, which illustrate the capacitance versus voltage profiles in detail.
    If you have any further questions or need additional information, feel free to reach out.
    Sergio J.
  • TKishi
    Hi
    Thank you for reply.
    Customer understand that Ciss, Coss, and Crss change depending on the VDS, but the customer would like to know how much they change at 800 VDS.This data is not available?
    Best Regard
    T Kishi
  • sjjimenezc
    Hi T Kishi,
    Unfortunately, we do not provide minimum and maximum values for Ciss, Coss, and Crss at 800 VDS. We only lists the typical values for these parameters under the specified conditions.
    Sergio J.
  • TKishi
    Hi
    I understand that there is no data available.
    I would like to confirm one more thing. Do you have data on gate charge characteristics (Vgs-Qg)?
    Regard
    T Kishi
  • sjjimenezc
    Hi T Kishi,
    Attached are the gate charge characteristics for the CAB450M12XM3 power module.If you have any questions or need further assistance, please feel free to reach out.
    Sergio J.
  • TKishi
    Hi
    Thank you for providing the data.
    Just one thing to confirm: the VGS data appears to be a very large value. Is it correct that the unit is (V)?
    Best Regard
    T Kishi
  • sjjimenezc
    Sorry about that, there was an issue when extracting the data causing a scaling on Vgs. Attached are the correct gate charge characteristics for the power module.
    Please let us know if you have further questions.
    Sergio J.
  • TKishi
    Thank you for your response!
    It was very helpful
    Best Regard
    T Kishi
    sjjimenezc
  • sjjimenezc
    Absolutely! Please don't hesitate to reach out if you have further questions.
