AC Input Voltage Sensing : Isolation ?
Hi Wolfspeed Experts .
I'm interested in referance design for AC/DC Converters for an DC Fast Charging product and i come across 2 Referance design :
[1] https://www.wolfspeed.com/crd25ad12n-fmc/
[2] https://www.wolfspeed.com/crd-22ad12n/
I was comparaing the ac input voltage sensing design and couldn't help noticing the presence of an Isolated Amplifier in [2] and not in [1] :
My questions will be :
1. Why [1] doesn't use an isolated amplifier ?
2. Since adding an Isolated Amplifier will cost more, why it was implemented in [2] ?
Looking forwards for your response.
Thank you & have a nice one.
Hi Retaw,
How you implement voltage sensing is determined by many factors like performance metrics or specific requirements of the intended application.
For [1], high voltage signals are routed onto the control board via wires to help with noise immunity where it is divided down using a high-impedance resistor divider referenced to a well established chassis ground. For applications that don't require isolated voltage sensing, this is a cheaper and robust solution.
[2] provides a great example of how to implement voltage sensing for applications that do require galvanic isolation - for instance, any automotive application such as an on-board charger. So while this could be more expensive, it is required by the application.
Each implementation has its inherent advantages and trade-offs, so we wanted to demonstrate multiple ways to implement a sensing solution.
Jonathan
