CLLLC DAB secondary side low-leg Vds ringing problem.
Hi Sir/Madam,
I have facing a problem which is the ringing happening on the low leg(Vds ringing) of the secondary side.
Do you have any experience with that?
How can I examine the root cause? parasitic inductance? layout? trr?
How can I reduce the ringing? Add a snubber?
Thanks a lot.
Hi Hin,
First check the gate timing of the secondary side. Is the sync rectification timing right? If the timing is not right, miss-alignment can cause significant ringing. Do you have waveforms?
BR,
Jianwen
