Footprints examples or typical footprint dimension documents
How do I find the footprint for CCB021M12FM3? I am using Kicad but any sort of example would be useful. Failing that, at least a "typical footprint" drawing that is properly dimensioned. I downloaded the "All-Power-KiCad-Files.zip" from this website, but the CCB021M12FM3 was not one of the part numbers included.
Hello andersonm,
I have sent KiCAD files for the CCB021M12FM3 to your registered email address. Please update here if you do not receive it shortly.
Brett
Haven't seen it yet...Out of curiosity, why aren't the files public?
Brett,
I never did receive anything to my registered email.
Hello andersonm,
I sent the email Thursday at 4:21pm CT, subject starting with "Wolfspeed Power Applications Forum", and I did not receive any kickbacks. This was to the email address on your profile at a corporate domain.
In the event your email server blocks certain types of files, I have re-sent the email as a TXT attachment. You will need to rename it to ZIP and extract. If you still do not receive it, please submit a private message, and we can transfer the files there.
We use external software to generate the layouts for various PCB software packages. The specific hole requirements for press-fit pins are not explicitly called out due to limitations with this process, and we don't have the capability to verify the footprints in all of the PCB software we can provide footprints for.
Brett
OK, we have a very sophisticated (and useless) email rejector on our corporate email. However, I did get the files from private message.
Matt
