CAB450M12XM3 Switching Energy vs. external gate resistance
Martin_L
Martin_L Contributor Level 1
edited July 2025 in Module Products
i think i've found a mistake in the datasheet of CAB450M12XM3 (Rev. 3, June 2024). Figure 15 should show the relationship between switching energies and external gate resistance but it shows the same information as figure 13 (Switching Energy vs. Drain Current (VDD = 800 V)). Is there already a newer version of this datasheet where this is fixed?
Best regards
Martin_L
  • AustinC
    Hello Martin_L,
    Yes, you are correct; on the latest revision (Rev 3) of the CAB450M12XM3 datasheet, Figure 15 and Figure 16 were not updated properly and are incorrect. We are working to correct this in an official revision update for the datasheet, but in the meantime, please see the correct figures below.
    Figure 15 MOSFET Switching Energy vs. External Gate Resistance
    Figure 16 Reverse Recovery Energy vs. External Gate Resistance
