Fail to import Wolfspeed Discrete Mosfet with Diode PLECS Model (.xml) to MATLAB
I've been using the SiC Mosfet with Diode .xml models on PLECS and they work perfectly. However, I plan to change my simulation to Simulink and I learned that MATLAB provides a function to import PLECS .xml model directly to Simscape MOSFET block.
I have tried to import a few discrete models for example C3M0016120D and E4MS025120U2. However, this function fails to import all Mosfet with Diode Model. This is the error that I received.
Also, I found that this function is also unable to import models that contains "lookup" function for example C4MS025120J2. This is how the lookup function is implemented in PLECS.
So far, the only models I have managed to import with ee_importDeviceParameters function are the legacy Mosfet models (separated Mosfet and body diode).
Has anyone been trying to do the same thing and faced this issue?
Thanks in advance!
