Where to buy CRD200DA23N-GMA
shengj2002
shengj2002 Contributor Level 1
I have two questions that needs your assistance.
  1. My project is interested in purchasing the CRD200DA23N-GMA (200 kW three-phase inverter). Currently, Richardson RFPD appears to be the only sourcing option, but I have not received any response from them. I have also contacted sales via the website, yet have not gotten a reply. Could you please advise if this product is available for sourcing at all?
  2. Additionally, we have a CRD25DA12N-FMC (25 kW three-phase inverter) that requires a Wolfpack power module replacement due to damage. Do you offer any repair services for this unit?
Sheng
  • DustinHill92
    DustinHill92 Wolfspeed Employee - Contributor Level 1
    Hello Sheng,
    Please see my responses to your questions below.
    I apologize that you have not received any correspondence currently. I have directly contacted the Sales Manager assigned to your account regarding your inquiry.
    This is not a service we have historically offered, but if you were to acquire a replacement module, PRD-02302: Wolfspeed Wolfpack® Mounting Instructions & PCB Requirements User Guide (PDF) provides extensive guidance on how to press-out the old module and press-in a new module. You will also want to download the Example WolfPACK® Mounting Files (ZIP). The necessary fixture models for the press/in and press/out processes are included, along with an example press assembly for the CRD25DA12N-FMC. Next, you will want to fabricate the following files:
    Press-Out
    • Example Press Out Tool - Flat Press - FM and GM Modules – 3D Print
    • Example Press Out Tool - Support Base - FM and GM Modules – Aluminum or High Percentage Infill 3D Print
    Press-In
    • FM Module Example Press In PCB Support – 3D Print
    • FM Module Example Press In Tool - Al2O3 – Aluminum or High Percentage Infill 3D Print
    Thank you,
    Dustin H.
