Phase shift bridge simulation in Speedfit
Zan_H
Zan_H Wolfspeed Employee - Contributor Level 2
I'm having trouble running a simulation for phase shift full bridge in Speedfit.
Using ideal diode and heatsink, simulation won't converge using below conditions:
Error message suggests inductances are too large however Speedfit doesn't allow user to change Cr and Lr manually.
Changing frequency from 80kHz with according Cr&Lr allows the simulation to run, however output power is limited to 10.95kW
Can someone look into this and let me know why Cr/Lr can't be changed manually, and why output power is capped?
Thanks!
Zan
