CRD-30DD12N-K Reference Design : gerber data for the control board
With respect to the reference design of CRD-30DD12N-K, we are going to build the control board by using the PCB design file of Control-0415p2.brd.
Meanwhile, by employing the Allegro ECAD software package, I have tried to generate the Gerber data from the PCB design file of Control-0415p2.brd.
After completing the Gerber data generation, the photoplot.txt file is created.
However some warning messages are generated in the photoplot.txt file: some of them are shown below as captured images.
Would you please review these warning messages?
I need to make this issue clear before I send the gerber data to the PCB house.
With regards,
GKIM
Hi GKIM,
It is about the line width setting of the assembly layer. no impact.
you can also use the gerber files in our design files. thank you
Frank
Hi FrankWei,
Thank you for your review.
There is no any gerber file in the PCB design files for the CRD-30DD12N-K reference design.
There are only Allegro PCB design files.
Would you please share the gerber files?
With regards,
GKIM
Hi GKIM,
I attach the gerber files here. thank you.
Frank
