CURRENT SHARING ON CLLC TOPOLOGY
Hi team,
Our design is based on CRD-22DD12N and our application is DC fast charging we are trying to implement current sharing between modules on CLLC Topology.
My questions:
1)Can we able to implement current sharing on CLLC Topology? please give your suggestions.
2)If we can implement the current sharing successfully! how many modules can be paralleled max?
Hi RakeshKumar,
Yes, you can implement the current sharing between converters. master/slave, voltage droop... you can do your design based on your requirements.
generally, I don't think there is a hard limit on the number of units in prallel. you can make the design and selection based on the system requirements and verify it.
