KIT-CRD-CIL12N-FMC Press fit
            Dear all
I bought the six pack evaluation board KIT-CRD-CIL12N-FMC as well as CCB021M12FM3 as targeted module. However when I received the board, I'm a bit confused how should I press it in when the holes are blocked. I attached the figure.
what is the standard process for this?
Thank you for your answer in advance.
            Hello, thank you for your message. A member of our technical team is looking into your questions and we will respond shortly. 0
            Hello wybcityu, Please refer to the user guide for the KIT-CRD-CIL12N-FMC found here: https://cms.wolfspeed.com/download/22071 The module is installed into the sockets on the bottom side of the eval board. We utilized sockets rather than a press-fit connection for the dynamic evaluation tool to allow for easy replacement of the power module. Best Regards, Austin C. 0
