Default Gate resistor used in PLECS XML Data
Hi Team ,
We are using PLECS Compatible xml data of C2M0025120D downloaded from your site. Would like to understand , this default PLCES data considers any external gate drive resistance ? If we have external gate Resistor in our circuit which is different than this default PLCES data , is there any way to modify this XML file to meet the external gate drive switching times ?
Hello Sivanshu,
The xml file takes care of scaling switching losses and therefore times with different external gate resistances. In the xml file you can see 2 formulas:
For Turn-on, the switching energy is dependent on the Rgon specified
Similarly for Turn-off, the switching energy is dependent on the Rgoff specified which gives you the flexibility choose different turn-off and turn-on gate resistances.
Please let me know if this answers your question. Thank you!
Thanks Bhatia . So if we have not specified any external gate resistor , Then the loss computation considers any default Gate resistor or Zero Ohms ?
Hi Sivanshu,
Currently, you'll need to specify an external resistor otherwise the simulator may assume zero for the external gate resistance. We're working on a model update that has default gate resistances built into the model structure and those will become available soon.
Zack
