Max Dvdt for 1200V 40mR TO247-4 Device
David2023
Contributor Level 1
I want to know the max dvdt for C3M0040120K ? 100V/ns ? Thanks.
Yes that is correct. You can also refer to this post. Thank you!
Thanks Tbhatia.
I find that infineon's datasheet (IMW65R060M2H)shows the max dv/dt is 200V/ns.
Could you please help double check the maximum dV/dt rating of C3M ? Thanks a lot!
Best regards
David
Hello David2023,
100V/ns is generally plenty for most applications. Are you just comparing specifications or do you really wish to switch that fast? Thanks!
Hello David2023,
Any update on your dv/dt requirements?
Thanks!
