CAS310M17BM3 Baseplate Material Data
Jake
Jake Contributor Level 1
edited June 16 in Module Products
Can you provide me with data on the material of the CAS310M17BM3 baseplate including the plate material, coatings applied, and material corrosion properties.
  • AustinC
    Hello Jake,
    The BM3 module family features a copper baseplate with an electrolytic nickel plating.
  • Jake
    Thank you. Do you know how thick the nickel plating is and where I can find more info about the specific material properties?
  • AustinC
    Hi Jake,
    I just reached out via email.
