EMI performance of CRD25DA12N-FMC
Hello everyone,
I am designing a three-phase EMI filter on the AC side of a 25 kW FM3 three-phase inverter (CRD25DA12N-FMC).
I am using a proper EMI test setup with LISNs and have already implemented a first passive EMI filter. However, even with relatively large filter components, I am unable to meet the Class B conducted EMI limits.
The main issue appears to be very high common-mode noise. I've tried increasing the common-mode choke and Y-capacitance, but the improvement is still not sufficient.
Has anyone worked with this inverter before or successfully passed Class B limits with it? or any other EMC test ? I would appreciate any insights regarding effective filter topologies, grounding/shielding practices, or known common-mode noise challenges with this platform.
Thanks in advance!
