Control strategy for CRD-30DD12N-K
With respect to the reference design of CRD-30DD12N-K, I wonder which control strategy is employed for the three-phase interleaved LLC DC/DC converter.
Would you please provide some information or document for its control strategy?
With regards,
GKIM
            Hi GKim, The control of this 3 phase interleaved LLC DC/DC is typical LLC control, frequency modulation. Since it is 3 phase, there is 120 degree phase shift in each phase. Sorry we don't have more document for control, since we just follow the standard LLC control method. There are quite a lot papers about this. Thanks, Jianwen 0
            Hi jshao, Thank you for your review. Would you please share a few paper titles that you think are most relevant to the standard LLC control method you follow? Thank you for your consideration. With regards, GKIM 0
            This one: and this one: and many on single phase LLC design 0
            Hi jshao, Thank you for your review. I have found that the IEEE paper for the trigonometric current balancing is very helpful. Meanwhile would you please share a few paper titles that you think are most relevant to the output voltage control you follow for CRD-30DD12N-K ? Thank you for your consideration. With regards, GKIM 0
            Hi Gkim, Please see attached paper from our team. Please check some reference papers at the end of paper. Hope that will help. Thanks, Jianwen 0
