CURRENT SHARING ON CLLC TOPOLOGY
            Hi team,
Our design is based on CRD-22DD12N and our application is DC fast charging we are trying to implement current sharing between modules on CLLC Topology.
My questions:
1)Can we able to implement current sharing on CLLC Topology? please give your suggestions.
2)If we can implement the current sharing successfully! how many modules can be paralleled max?
            Hi RakeshKumar, 1)Can we able to implement current sharing on CLLC Topology? please give your suggestions. Yes, you can implement the current sharing between converters. master/slave, voltage droop... you can do your design based on your requirements. 2)If we can implement the current sharing successfully! how many modules can be paralleled max? generally, I don't think there is a hard limit on the number of units in prallel. you can make the design and selection based on the system requirements and verify it. 0
