C4MS012120QT LTspice Model
Will there be a LTspice model releasing soon for C4MS012120QT?
Hi Steven,
Here is the LTspice model for C4MS012120QT. Please feel free to reach out if you need anything else.
Hi Mhusain,
Thank you for your response. It seems to me that this model may have a problem. Even trying to run it with a simple pulse to turn on and off the device won't allow the simulation to run and runs into an issue with G11 (gate–drain capacitance calculation).
Hi Steve,
Could you please share the simulation file (.asc) where you are encountering this issue, along with either a screenshot of the error message or the SPICE output log (.log file)? This will help us investigate the problem further.
Hi Mhusain,
Attached is the LTspice simulation file that I created to test the C4MS012120QT model. The error is a convergence stall which can be seen in the .log until I manually stop the simulation, but the simulation will not run beyond this point regardless.
Hi steve,
Can you try this model. I updated the models and made it more convergent friendly. Let me know how it performs.Regards
