Official current LTspice models for C3M0075120K and C4D05120A; document-library access issue
Mohammad
Mohammad Contributor Level 1
Hello Wolfspeed Power Applications Support,
Please provide a working official download link for the current manufacturer-issued SPICE/LTspice models for these exact parts:
  • C3M0075120K (TO-247-4, not the K1, K-A, D or J variant).
  • C4D05120A (TO-220-2, not the E or D variant).
The LTspice/PLECS document-library page is displaying a blank page in our Windows browser, so we cannot obtain and identify the current model package through the normal download route. A direct public Wolfspeed download link or the official supported alternative would help. If registration or a license acceptance is required, please provide the official steps for the owner to complete.
For each model, please confirm:
  1. Revision, release date, whether it is the current recommended version, and the exact model filename/subcircuit name.
  2. Supported simulator and version; any syntax limitations in LTspice or ngspice.
  3. Subcircuit pin order, including the Kelvin-source and thermal terminals where present; supplied symbols, dependencies, example circuits and installation instructions.
  4. Supported voltage, current, temperature and gate-drive ranges; whether self-heating, nonlinear capacitances and relevant diode dynamic behavior are included, and any documented limitations.
  5. A manufacturer reference test/example and the datasheet revision used for model validation.
  6. Applicable model license, permitted local use, and whether redistribution inside a design-evidence archive is allowed. A published checksum is welcome if available.
No project files or personal contact details are attached to this request. We will keep the existing model files unchanged and separately verify any supplied replacement before using it.
Thank you.
  • BlakeNelson
    Hi Mohammad,
    We do not require you to provide any personal details to access our models but we have recently updated our captcha system to reduce AI scraping of our website. When you open one of the links, it may immediately download the file or you may have to click a standard captcha box.
    {DF65C042-6BEE-49FD-9945-07E9053A022E}.png {6B5A164A-F960-473A-B302-6CCBBE184633}.png
    You can find all our model downloads here:
    https://www.wolfspeed.com/tools-and-support/power/ltspice-and-plecs-models/
    Or for our PLECS models specifically: https://assets.wolfspeed.com/uploads/2025/10/Wolfspeed_All_PLECS_Device_Models.zip
    And for SPICE:
    https://assets.wolfspeed.com/uploads/2023/09/Wolfspeed_SPICE_Models.zip
    I was able to get all these to work this morning.
    Most of the information you are asking for can be found in the SPICE models, which often have helpful notes in the commented out header. The C3M0075120K was last updated in 02-24-2021, for example.
    We are always aiming to be compatible with latest version of LTspice, but at times they have introduced updates that create new syntax errors in our models. If you encounter any issues running our models in the latest LTspice, please let us know on this forum and we will update the models.
    A symbol is provided in LTspice and Pspice for both parts you requested.
    As for licensing, our models fall under our terms of use, https://www.wolfspeed.com/legal/terms-of-use/, which allows for evaluation of our products for use in your business but disallows redistribution with consent.
    Blake
