Gate drive fault in Power Converter example design
I found a gate drive fault on a LTspice Power Converter model. you can see the red box on the schematic, the switch's source is quite weird according to the gate drive wave. after I changed the minus source 'V-' to 'ground', It looks pretty well. I would appreciate it if you could re-upload the LTspice converter models that corrected these errors.
Also, is there any plan for SiC SPICE model references to be uploaded? It would be great if you could upload more data on the LTspice contents of comparing the SPICE models or Power converter models(powered by LTspice) distributed by wolfspeed with the actual real measurement results. And, do you support LTspice models for SiC power modules?
