3d model for controller board v1.2
TUIMK
TUIMK Contributor Level 1
edited April 2023 in General
the CAD files for the CRD300DA12E-XM3 seem to show an updated or different version regarding the main control-board. Our CAD-program calls it "X18-Controller-V1-8" and the board-revision we have is V1.2. The main differences found so far are the following:
  • missing mounting holes on the bottom corner (between J1/J2 andJ2/J3)
  • fan connectors J12 and J13 are rotated
  • LEDs DT6 and DT7 and their resistors etc. got moved
Is it possible to get the (older) CAD files for our board-revision?
Manuel
  • ARStorment
    ARStorment Wolfspeed Employee - Contributor Level 1
    Hello Manuel,
    Please find attached the ZIP file for the STEP of X18-Controller-V1.2 and for the entire inverter assembly. Let me know if there's anything else you need.
    Drew
  • TUIMK
    Hello Drew,
    thanks for your reply. These are the files I was looking for. 👍️
