CAD files for Pess-In Fixturing
Duclair
Duclair Contributor Level 2
edited August 2023 in Module Products
I would like to have CAD files for press-in fixturing for FM3 and GM3 devices depicted in Figure 9 of CPWR-AN41.
Also, do you have a recommended manufacturer for these parts?
Best regards.
  • ArunA
    ArunA Wolfspeed Employee - Contributor Level 2
    Hi Duclair,
    Please find the files attached. Unfortunately, we do not have any list of recommended manufacturers.
  • Duclair
    Ok, thanks.
  • Duclair
    Hi ArunA,
    Can you please attach also the stencil CAD files for TIM application used for FM3 and GM3 packages, referenced in CPWR-AN42.
    Best regards.
  • ArunA
    Hi Duclair,
    Please find the step files attached.
  • Duclair
    Hi ArunA,
    Can you advise what material should be used to print the press-in fixturing?
    Best regards.
  • ArunA
    Hi Duclair,
    For prototyping, any normal 3D printing material (e.g ABS) should work. But please be advised that plastics undergo compression under force and can have an impact on the pattern. This is to be taken into consideration.
    For production press fit tooling, we recommend metal press fit tooling using some subtractive manufacturing process (e.g milling).
    I would also like to request you to create new questions for new topics rather than commenting on the original question. This improves traceability for future users of the platform.
  • Duclair
    edited August 2023
    Ok, thanks.
    I will do as required next time.
