CCB021M12FM3 installation
David_William
David_William Contributor Level 1
edited May 2023 in Module Products
  1. Could I apply for the footprint file of CCB021M12FM3?
  2. When I use CCB021M12FM3, could I solder this module to the PCB instead of using the press-fit contact method?
Thank you!
  • AustinC
    Hi David,
    1. Yes, we can supply the footprint file for the 21 mΩ six-pack FM3. Which PCB layout software are you using?
    2. Yes, you can solder the module into a PCB instead of performing the press-in procedure.
  • David_William
    Layout software: Altium Designer (21.0.8).
    Many thanks for your response!
    David
  • ArunA
    ArunA Wolfspeed Employee - Contributor Level 2
    Hi David,
    We have send the footprint files to you via email.
    ArunA
  • David_William
    Thanks so much for your kind response, I will have a test of this module based on your footprint!
