CCB021M12FM3 installation
David_William
Contributor Level 1
- Could I apply for the footprint file of CCB021M12FM3?
- When I use CCB021M12FM3, could I solder this module to the PCB instead of using the press-fit contact method?
Thank you!
Hi David,
- Yes, we can supply the footprint file for the 21 mΩ six-pack FM3. Which PCB layout software are you using?
- Yes, you can solder the module into a PCB instead of performing the press-in procedure.
Layout software: Altium Designer (21.0.8).
Many thanks for your response!
David
Hi David,
We have send the footprint files to you via email.
ArunA
Thanks so much for your kind response, I will have a test of this module based on your footprint!
