Debugging Example Code for 300 kW XM3 Three-Phase Inverter [CRD300DA12E-XM3]
Hey,
I'm running the example code for the 300 kW XM3 Three-Phase Inverter but I am receiving an error whenever I attempt to debug the code as per the instructions in the example code from the manual. I receive 2 error screens back to back as soon as debug the code which I have attached below. What can I do to resolve this issue?
Any help would be greatly appreciated. Thank you!
Error Screen 1:
Error Screen 2:
1 -
Can you please verify the settings in the General Properties window matches the below and that the correct configuration is active?
