Firmware file missiong when configure nxp control card for Evaluation Board
I bought half-bridge evaluation board and nxp control card. Now I want to configure my control card to give PWM signal. I go to the website (https://forum.wolfspeed.com/home/leaving?allowTrusted=1&target=https%3A%2F%2Fwww.wolfspeed.com%2Fspeedval-kit-control-cards%2F) to download firmware and GUI. As the handbook discribed, there should be an file with form ".elf" but there is no files like this in the website. Could you please check if firmware of NXP is available?
Here is the screenshot of handbook for NXP control board configuration. To load the firmware, a file ".elf" is needed.
1 -
Hi Puzhen_Yu,
Please see the directory or location of the file as highlighted with the box in the attached image. The file name is also updated, the image below should help you navigate to the right location:
I hope this helps.
Urvi
2 -
